Post by spyphish on Sept 19, 2018 8:06:44 GMT -5
This driveline was in the rusted WI SP cruiser that we are parting out. Engine had original lean burn on it and started, went to fast idle etc. Cooling system held 15 lbs test for over an hour. Trans shifted through all gears fine. All fluids look great. It does have an intake valve pop thru carb at WOT so something is stuck or burnt. It did run better with a half quart of tranny fluid thru the carb. Great candidate for fresh up as 96k showing on odometer. Will need an oil pan as this one is beat up. Comes without front plumbing ie AC, PS, HD Alt. $1200 plus trip to Fastenal email stephenontheriver@yahoo.com I interested
Post by spyphish on Dec 7, 2018 8:42:13 GMT -5
Ran all day yesterday. Great compression, valve springs check to spec, no leaks etc. It has a flat cam. $1200 as is or $3k if we fix/clean/freeze plugs/paint etc. Real HP 440 with tranny. Update. New parts on the way. Cam was toast. Definitely the original HP motor and you can have a "sip of tea" out of those lifters......
Post by spyphish on Dec 13, 2018 8:32:16 GMT -5
Post by spyphish on Dec 14, 2018 3:55:19 GMT -5
Post by cynot on Dec 14, 2018 7:58:05 GMT -5
What cam did you go with?
Post by spyphish on Dec 14, 2018 18:30:21 GMT -5
May have to soften metering rod spring as slight loss of vacuum. Monaco has same setup and runs fine.
Post by spyphish on Dec 16, 2018 15:06:00 GMT -5
Runs and shifts fine with lots of new parts. $3500 can text a vid 337-499-44 three five
