Post by fozz71 on Mar 26, 2024 18:32:20 GMT -5
Hey fellas, can't get my starter to crank when I hit the key? have no clue why not, replaced solenoid and no cranking....bizarre.
Anyone have a good clear wiring diagram for the 74-75 Monacos?
Thanks, James
Post by tk826 on Mar 26, 2024 22:47:21 GMT -5
Hopefully these help. Attachments:
Post by fozz71 on Mar 28, 2024 14:57:33 GMT -5
Thank you for the schematic. It’s really strange when I jump across the starter relay the starter motor cranks, but I can’t hit it with the key? Both the starter relay and the solenoid work just fine so now I’m stumped.
Post by flcl64 on Mar 29, 2024 1:42:16 GMT -5
Is the ignition switch broken or the neutral safety switch? Try starting the car in neutral rather than park.
Post by fozz71 on Mar 29, 2024 7:02:29 GMT -5
I'll try that, thanks. I also realized that since I jumped the relay, it still could be a bad relay.
