Post by Steam McQueen on May 7, 2016 20:52:23 GMT -5
Post by Steam McQueen on May 14, 2016 13:29:50 GMT -5
Post by srt440 on May 14, 2016 13:55:25 GMT -5
Curious, can a '74 grille and tail lights be swapped onto a fury? Looks like it has the right fenders.
Post by 58hemifury on May 14, 2016 18:39:52 GMT -5
Curious, can a '74 grille and tail lights be swapped onto a fury? Looks like it has the right fenders. I assume you mean Monaco when you say '74? The header, headlight frames, grille and front bumper will swap over as a set, not individually, tail lights as far a I can tell no.
Post by oldcigarette on May 25, 2016 23:01:03 GMT -5
What the heck is going on with that front fender??
Post by gtopat on May 26, 2016 13:47:21 GMT -5
Curious, can a '74 grille and tail lights be swapped onto a fury? Looks like it has the right fenders. I assume you mean Monaco when you say '74? The header, headlight frames, grille and front bumper will swap over as a set, not individually, tail lights as far a I can tell no. Yes and no. The header/grille will bolt on and the dual headlight brackets are exactly the same. The issue is that the shape of the Fury fenders are different than the Monaco, so the top-outer corners of the Monaco headlight bezels will hang over beyond the fenders. Also, Monaco fenders are a fraction of an inch wider. Fury taillights are much bigger than Monacos and sit up higher. The Fury doesn't have the rear filler panel.
Post by Steam McQueen on Sept 5, 2016 13:19:21 GMT -5
Post by Steam McQueen on Dec 9, 2016 0:01:26 GMT -5
