automobile-catalog.com Monaco specs
Oct 11, 2011 18:37:59 GMT -5
Post by sigmfsk on Oct 11, 2011 18:37:59 GMT -5
If you go to
www.automobile-catalog.com/
and do a search on a 1974 Dodge Monaco, 4-door sedan, you get the following info.
Some interesting info there. I don't know how they estimated a Cd of 0.5, but that's the same as what I estimated here:
bluesmobiles.proboards.com/index.cgi?action=gotopost&board=owners&thread=45&post=2032
DODGE MONACO 4-Door Sedan 440 V-8 TorqueFlite
as offered for 1974 in North America U.S.
Production/sales period: 1973 - 1974
Modelyears: 1974
Country of origin: USA
Make: Dodge (U.S.)
Model: Monaco 3gen-Royal Monaco 1974-1977
Type: Monaco Base 4-Door Sedan 1974-1976
Optional equipment:
EEC segmentation: F (luxury cars)
Class: full-size / executive car
Body style: sedan
Doors: 4
Traction: RWD (rear-wheel drive)
Dimensions & capacities
Length: 5601 mm / 220.5 in
Width: 2014 mm / 79.3 in
Height: 1392 mm / 54.8 in
Wheelbase: 3099 mm / 122 in
Front track: 1625 mm / 64 in
Rear track: 1610 mm / 63.4 in
Ground clearance:
Fuel: 95 liter / 25.1 U.S. gal / 20.9 imp. gal
Turning circle btw. walls: 14 m / 45.9 ft
Turning circle btw. curbs:
Drag coefficient claimed:
Drag coefficient estimated by a-c: 0.5
Legroom:
1st row: 42.2 in / 1072 mm
2nd row: 38.2 in / 970 mm
3rd row:
Shoulder room:
1st row:
2nd row:
3rd row:
Headroom:
1st row: 38.7 in / 983 mm
2nd row: 37.8 in / 960 mm
3rd row:
EPA passenger volume:
Interior length:
Interior width:
Interior height:
Trunk cap. claimed:
Trunk cap. SAE: 578 / / dm3, 20.4 / / cu ft
Trunk cap. VDA:
Boot length:
Boot length max.:
Boot width:
Boot width min.:
Boot height:
Load height:
Weights
Curb weight (without a driver): 2018 kg / 4449 lbs
Dry weight:
Shipping weight:
Curb weight estimated:
GVWR:
Payload:
Payload estimated:
Sales markets, North America, U.S.
Related models:
Powertrain
Engine manufacturer: Chrysler RB-series V-8 440
Engine type: spark-ignition 4-stroke
Fuel type: petrol (gasoline)
Fuel system: carburetor
Charge system: naturally aspirated
Valves per cylinder: 2
Valves timing:
Additional features: Carter 4-barrel
Emission control:
Emission standard:
Cylinders alignment: V 8
Displacement: 7206 cm3 / 439.7 cui
Bore: 109.73 mm / 4.32 in
Stroke: 95.25 mm / 3.75 in
Compression ratio: 8.2 : 1
Power net: 164 kW / 223 PS / 220 hp (SAE net) / 4000
Torque: 468 Nm / 345 ft-lb / 3200
Power gross:
Torque gross:
Redline rpm:
Drivetrain
Gearbox: Chrysler TorqueFlite
Transmission type: automatic
Number of gears: 3
Gear ratios (overall):
I 2.45 (6.76)
II 1.45 (4)
III 1 (2.76)
IV ()
V ()
VI ()
VII ()
VIII ()
R 2.2
Speed range (max speed on gears, top gear value theor.):
(km/h/mph)
I: 88 / 55
II: 148 / 92
III: 215 / 134
IV: /
V: /
VI: /
1000rpm speed:
(km/h/mph)
I: 20 / 12.4
II: 33.7 / 20.9
III: 48.9 / 30.4
IV: /
V: /
VI: /
Torque converter factor: 2.02
Final drive ratio std: 2.76
optional: 3.23
Standard tires: HR78 x 15
Approach angle (deg):
Departure angle (deg):
Ramp angle (deg):
Modelyears: 1974
Make: Dodge (U.S.)
Optional equipment:
Body style: sedan
Doors: 4
Ground clearance:
Legroom:
3rd row:
Shoulder room:
1st row:
2nd row:
3rd row:
Headroom:
3rd row:
Interior length:
Interior width:
Interior height:
Trunk cap. claimed:
Trunk cap. VDA:
Boot length:
Boot length max.:
Boot width:
Boot width min.:
Boot height:
Load height:
Weights
Dry weight:
Shipping weight:
GVWR:
Payload:
Payload estimated:
Related models:
Powertrain
Valves timing:
Emission control:
Emission standard:
Power gross:
Torque gross:
Redline rpm:
Drivetrain
Number of gears: 3
I 2.45 (6.76)
II 1.45 (4)
III 1 (2.76)
IV ()
V ()
VI ()
VII ()
VIII ()
R 2.2
(km/h/mph)
I: 88 / 55
II: 148 / 92
III: 215 / 134
IV: /
V: /
VI: /
1000rpm speed:
(km/h/mph)
I: 20 / 12.4
II: 33.7 / 20.9
III: 48.9 / 30.4
IV: /
V: /
VI: /
optional: 3.23
Ramp angle (deg):
