Post by srt440 on Mar 6, 2017 0:20:40 GMT -5
I need suggestions on what 9.25 will bolt up to a 77 Monaco? Mine has a 8.25 now and that's not gonna work for my build. Is there a car I can look for that will make this swap easy? Other option is 8.75..But I'm sure it would need surgery to work. Suggestions please. Thanks
Post by 58hemifury on Mar 6, 2017 10:00:58 GMT -5
'74 Monacos and other C-bodies came with 8 1/4, 8 3/4, and 9 1/4 rears so an 8 3/4 isn't unheard of as a bolt in, just not as common. Any '74-'78 C-Body rear should bolt in.I assume you are asking about a Royal Monaco, when you ask for advise and parts remember the Monaco in '77 was a B-Body and the Royal Monaco was the C-body.
Post by warsip2k15 on Mar 6, 2017 13:14:00 GMT -5
Also of I remember correctly the driveshaft is also a different length I think you would have to shorten yours a little or grab the shaft out of the donor.
Post by srt440 on Mar 6, 2017 13:44:27 GMT -5
Yea sorry..I keep forgetting the B & C body 77. I did locate a 9.25 from a Imperial that has factory disc brakes.
Post by 58hemifury on Mar 6, 2017 14:52:39 GMT -5
Yea sorry..I keep forgetting the B & C body 77. I did locate a 9.25 from a Imperial that has factory disc brakes. If you do that make sure you grab the proportioning valve and I believe the master cylinder is different. Also depending on the budget you have for this build I would check on price and availability of the parts for the disc brake rear, I know a few years ago they were outrageous.
Post by srt440 on Mar 6, 2017 17:09:41 GMT -5
Rockauto seems to have most of it, rotors, calipers, etc. Is there a part that u know of that would be expensive or hard to find? Gonna buy a new master cylinder, I'd never use anything like that from a salvage yard.
Post by 58hemifury on Mar 6, 2017 18:43:41 GMT -5
Back in the day someone told me calipers and rotors were almost impossible to get for them, it was the late eighties and only dealers sold them, I didn't know if they ever became common for the aftermarket
Post by srt440 on Mar 6, 2017 19:07:35 GMT -5
Mopar has been riding the 9.25 band wagon now for ever. Even the Dakotas, Durangos, and Rams have them..From what I can tell nothing has changed over the years other than the different widths they came in. Wasn't really looking for discs but these kinda feel in my lap.
