Post by mrroverrover on May 11, 2015 1:31:32 GMT -5
Before I get stuck into it. I need to fit the new sender unit in the gas tank, is it much aggro to drop the tank to do it or not too bad? Looks like you can't do it without dropping the tank Sent from my SM-G900F using proboards
Post by christine58 on May 11, 2015 13:00:06 GMT -5
They arent too bad to remove, good chance to clean, paint, rust proof the top of the tank/trunk floor aswell. Also renew any rubber hoses and clamps, if they are still original replacement is due.
Post by spanks79 on May 11, 2015 19:43:15 GMT -5
I agree with Christine's comments. I will add that it's much easier with an empty/next to empty tank. Spray some penetrating oil on the j bolts before you start to avoid breaking them. New bolts are available if needed. I just had to re drop my tank to replace the sending unit a couple weeks ago. I tried to get cheap and re use the old sending unit and it was not working. Ended up having to install a new one. When I installed the new sending unit the lock ring went in really easy. Once I refilled the tank it leaked like crazy. I ended up stacking two rubber gaskets under the sending unit between the tank. This made the lock ring hard to install but it was tight and no leaks.
I assume you tested the gauge to ensure it is working and tge sending unit is in fact bad?
Post by 58hemifury on May 12, 2015 5:34:04 GMT -5
The gauge is an NOS one and I tested it by grounding the wire at the sender when I had the car.
Post by mrroverrover on May 12, 2015 12:32:04 GMT -5
The gauge is an NOS one and I tested it by grounding the wire at the sender when I had the car. Cheers for advice all. It's a new gauge then. I did wonder why the holes don't line up. Must be from another year? I took the speedo apart to clean and repair pins so I made the guage fit better too as it was wobbling about lol. Sent from my SM-G900F using proboards
Post by 58hemifury on May 12, 2015 19:26:29 GMT -5
The gauge is an NOS one and I tested it by grounding the wire at the sender when I had the car. Cheers for advice all. It's a new gauge then. I did wonder why the holes don't line up. Must be from another year? I took the speedo apart to clean and repair pins so I made the guage fit better too as it was wobbling about lol. Sent from my SM-G900F using proboards It's what I got on ebay that was listed for the car, it fit and I was hoping it'd work.
