Post by mrroverrover on Apr 13, 2015 17:09:42 GMT -5
Well. ...................this is it So it's finally here. It's like all my Christmas's come at once lol. Love the car Adam did a great job of it. Bit of an issue now though is our won't start I assume they drained all fuel from it before shipping. We put 10ltrs in it but there's just no fuel getting to the carb. Any ideas? An I missing something really silly? is there just one mechanical pump and that's it? Sent from my SM-G900F using proboards
Post by mrroverrover on Apr 13, 2015 17:14:03 GMT -5
This is me! Forgot my sunglasses though lol. Sent from my SM-G900F using proboards
Post by Ghostbluesman (Ghostsoldier) on Apr 13, 2015 17:14:40 GMT -5
Ben,
Pour some fuel down the carb throat, let it set for a moment, then turn the key over while pumping the accel pedal, and hold the pedal to the floor until it fires off.
Sounds reckless, but it damn sure works....been doing it for years, with never an issue (when it's turning over, you're getting oil to the top end).
Post by mrroverrover on Apr 13, 2015 17:39:19 GMT -5
Ben, Pour some fuel down the carb throat, let it set for a moment, then turn the key over while pumping the accel pedal, and hold the pedal to the floor until it fires off. Sounds reckless, but it damn sure works....been doing it for years, with never an issue (when it's turning over, you're getting oil to the top end). Rob Excellent tip cheers. Will try that tomorrow when daylight returns and work isn't in the way! We did pour some fuel in the carb and it did fire on it. It just doesn't seem to be getting any fuel pumped from the tank. Sent from my SM-G900F using proboards
Post by Ghostbluesman (Ghostsoldier) on Apr 13, 2015 17:53:33 GMT -5
Yeah, the carb is just basically an air pump, so holding the primaries open will give you the air you need to fire the fuel. Let us know how it works!
Post by countrybunker on Apr 13, 2015 20:22:15 GMT -5
Congrats!! You must be estatic to actually have a car in front of you finally. Shes looking good!
Do as Rob said, and you should be good. The pump is mechanical, and the engine needs to be running to get the fuel up to the carb. Get enough gas in the carb for the engine to run long enough to get the gas up there. Done it several times myself.
Happy motoring
Post by Sd.Kfz. 400 on Apr 14, 2015 4:22:25 GMT -5
Finally! Good luck with the car. And add more petrol.
Post by spanks79 on Apr 14, 2015 9:35:31 GMT -5
Glad it made it safe.
You may want to check for moisture or water in the fuel if you cant get it going. You could always pop the fuel line off at the carb and crank it over carefully and see if fuel is pumping.
Post by mrroverrover on Apr 14, 2015 13:21:35 GMT -5
Glad it made it safe. You may want to check for moisture or water in the fuel if you cant get it going. You could always pop the fuel line off at the carb and crank it over carefully and see if fuel is pumping. Our lady of blast acceleration. ............ It's alive! !!!!!!! Followed above above. Poured some fuel in carb, a few more jerry cans in the tank and got it started. Done a few bits that I'll update you on later. Now just got to wait for the paperwork so I can go get mot and legal! !! Cheers all. Sent from my SM-G900F using proboards
Post by AZBlues on Apr 14, 2015 14:25:27 GMT -5
Congrats. Post a vid of the reactions of people on the street as you drive by. I bet it would make an Aventador fade in the distance.
Post by 58hemifury on Apr 14, 2015 20:51:19 GMT -5
I'm glad it's alive and well, and more importantly you are happy with it. Enjoy Ben.
Post by mrroverrover on Apr 19, 2015 11:05:53 GMT -5
So today I fixed the heater controls that didn't adjust anything. It was just a pipe popped off under the dash! ! Also fixed the non working right blinker indicator. Was just a bit of a dodgy connection on the round multi plug on that side. I just unplugged it cleaned contacts and plugged back in securely. Now I know what way I'm indicating lol. Also removed the clock to try and repair it. There is power getting to it so I'll try fixing the clock itself somehow. I managed to get the radio out, but put it all back in as I'll have to wait for the fm modulator I've ordered to do a stealth mp3 install. Not sure if it was working in usa but I can't tune into anything here. Still haven't driven it yet as still waiting for title from the shippers before I can do anything Those bulbs in the foot wells, should they light when you open doors? They don't now and the bulbs are ok? The other interior lights work fine. Sent from my SM-G900F using proboards
Post by countrybunker on Apr 19, 2015 12:40:03 GMT -5
Yea those lights should light up with the doors. I drove mine around for 2 years before i found those bulbs. They were burnt out. Replaced em, and what a difference.
Post by antblues on Apr 20, 2015 13:30:30 GMT -5
Ah looks awesome mate Well done!!!
Post by mrroverrover on Apr 24, 2015 8:59:27 GMT -5
I think the Title has finally arrived at home!!!! So it's MOT this weekend then a 2 to 6 week wait for the UK registration. Woohoo.
