Post by AZBlues on Jan 1, 2015 0:07:00 GMT -5
What are you guys with 440 cars running? I have a radiator in nice shape from a 400 car for my swap/build, it's a two row. I'd like a three row but I can't find any listing on one. Is the 2 row good enough for a warmed over 440 with A/C in the desert? I'm suspect at best.
-AZB
Post by cbodymopar on Mar 14, 2015 7:43:09 GMT -5
the last one I bought from Oreillys was a 2 core, but it was a wide 2 core, seemed to be closer to the size of a 3 core, definetly better than the factory 2 core. also, if you get a factory 3 core, as long as the tanks are in descent shape, there are companies that can build them back to original. I've got a friend that does it for a living. he does lots of tractors radiators and gas tanks, as long as he has mostly the original shape, he can build just about anything.
Post by AZBlues on Mar 14, 2015 10:42:57 GMT -5
Thanks, I wasn't aware that some of the new ones were wide 2 rows. Makes sense. Around here, there is a radiator company that will convert a stocker to a three row - but at over $500, I'd rather look around.
-AZB
Post by cynot on Mar 14, 2015 12:25:06 GMT -5
I found a bunch of aluminum radiators on EBAY for Monacos. Prices start around $175, but I am not so sure of the quality. They all claim made in USA, lifetime guarantee etc... but the price seems too good to be true. I would like to try one but my luck it would leak. Seems too cheap for a quality part.
Post by cbodymopar on Mar 14, 2015 16:46:41 GMT -5
Oreilly part number 433506 $206.99, but if you have shop account its more like $180 if I remember correctly and they are copper tank and brass core - It don't look like a wide 2 core, just regular but not positive link
Post by Ghostbluesman (Ghostsoldier) on Mar 17, 2015 10:41:49 GMT -5
If it's any consolation, I run a 2-core, 6-cylinder radiator in my slightly warmed-over Ford 302/C4 combo in the ol' '62 Ratwagon; I've never had an issue with it overheating here in Florida, even in the summertime. I'm going to use the 2-core, 360 radiator that came with my cop car, when I drop the 440 in the Blumo, and I'm hoping to have the same good luck. Rob
Post by Mr Mercer on Mar 18, 2015 1:36:44 GMT -5
I have a 2 row high efficiency rad (that's what I was told when purchased) and its never over heated my 440 .
The tanks are a lot smaller than my original which I should of kept to have it redone . Also helps to have a separate trans cooler to keep the heat down . Mine came with a huge factory one .
Post by Ghostbluesman (Ghostsoldier) on Mar 18, 2015 11:18:41 GMT -5
Yep...there's no substitute for an external trans cooler, a temp guage (not an idiot light), and extra electric cooling fans (there's plenty of room). I ran a 2-core 318 radiator in my '68 Dart 440 (now the Blumo mill) for years on the street, and never had an overheating problem (just a rear traction one, lol). Rob
