Post by Sean Belushi on Jul 26, 2012 18:45:45 GMT -5
What is the correct location for drilling for the spotlight ?
Post by sigmfsk on Jul 26, 2012 20:57:04 GMT -5
Hi Sean: Are you installing a 216 exterior mount, or 215 interior mount? They use differently located holes. I put some pics here: bluesmobiles.proboards.com/index.cgi?action=gotopost&board=screen&thread=582&post=5514If you're installing a 216 exterior mount, there's an installation kit with instructions that show where the hole is drilled. If you're installing an interior 215 mount, you're a bit on your own, as the instructions were only sent to the factory. The blumo had its spotlight all over the place, so for screen accuracy it seems you can just find any spot reasonable and drill.
Post by Sean Belushi on Jul 26, 2012 21:33:10 GMT -5
Hi Sean: Are you installing a 216 exterior mount, exterior I put some pics here: bluesmobiles.proboards.com/index.cgi?action=gotopost&board=screen&thread=582&post=5514Thanks! If you're installing a 216 exterior mount, there's an installation kit with instructions that show where the hole is drilled. The blumo had its spotlight all over the place, so for screen accuracy it seems you can just find any spot reasonable and drill.About what I'm gonna do
