black / white paint scheme
Apr 28, 2012 7:30:18 GMT -5
Post by sigmfsk on Apr 28, 2012 7:30:18 GMT -5
Lots of info from here:
www.bluesbrotherscentral.com/forum/topic/5392-black-and-white-paint-startstop/#entry76192
black
- Fenders, hood, and everything forward (red primer spot discussed in another thread)
- quarter panels, trunk
- rocker panels front and back
roof: white
front door
- outside lower: white
- outside window frame: white
- inside window frame: white
- inside rear edge: driver can be black or white, passenger is always white
rear door
- outside lower: black
- inside window frame: white / black. It's white just on the inside lip, but black for the main portion. See the Blue Lou pic below.
- inside rear edge: black
a-pillar white, outside and in
other areas described below:
c-pillar dividing line (from white roof to black quarter panel)
b-pillar / door jamb area
c-pillar dividing line (hidden when rear door closed)
Many pics of the blumo in the "exterior trim" thread:
bluesmobiles.proboards.com/index.cgi?board=screen&action=display&thread=699
Check them out, and I add some here.
Black on inside of window frame and rear edge of rear doors.
Some front door rear edge shots:
If you look at the "exterior trim" thread, most of the pics show the dividing line basically horizontal, ending a bit lower than the upper edge of the rear door:
examples:
but here's one pic where the line is a little higher (but still lower than the upper edge of the rear door)
and if you look at the hi-res dancing kids pic from www.74monaco.com
www.74monaco.com/74-monaco-website/hires-blumo/hires-blumo-13.html
that dividing line curves up so that it meets the upper rear edge of the door
TK826 and I did some chatting about the line on BBC, about whether the dividing line would be better BELOW the chrome strip, or ABOVE the chrome strip. I think both could be screen accurate.
For my car, I'm thinking above chrome strip would be a good screen accurate spot. So that would make the dividing line the same as the white/green line on Marin County:
and down about 3/8" from an easy-to-measure part of the body:
up to a 1" drop could be within the range of screen accurate:
But that's just one plan; that dividing line has a lot of screen accurate options. It looks like anywhere from 0" to 1" down is fine.
b-pillar / door jamb area : complicated
The b-pillar is always white where visible with the doors closed:
The lower portion can also be white:
Or black:
and then the fall-apart car:
Having a dividing line seems common.
Here's what MBMOPAR did:
And here's a pic of a 1974 Chicago PD Monaco (presumably showing a factory placed dividing line)
My Marin County b-pillar was all green top to bottom, so it's not much help:
Here are some pics from the BBC thread. I include here to provide some ideas of decisions to be made when painting.
The way Huey paints his blumos:
Swedish bluesmobile:
$25K blumo
Marin County doesn't have one:
I think there are only two times that a rear door is opened in the movie, and I can't make out any divider details either time:
I think we only have the fall-a-part car, which doesn't have the angle to show if there's a dividing line or not:
We have this alternate angle pic of the same scene:
This might not be considered screen accurate, but it's a hint of what the movie blumo could look like (including a non-AC blockoff plate). It doesn't seem to show the dividing line either.
But since the bottom of the c-pillar is black, and the upper of the b-pillar is white, there has to be a dividing line somewhere, it makes sense to me to put it at the same place as the CPD:
Post any suggestions/corrections, and I'll edit this top post to keep it up-to-date with the most recent/correct info.
thanks,
black
roof: white
front door
rear door
examples:
Or black:
$25K blumo
thanks,
