Post by legendaryacura8 on Feb 25, 2012 21:02:39 GMT -5
Not sure if this is the right thread, but an old Craig 8 Track player, which wires go where? Black and Red are pretty self explanatory, but which wires are positive.negative for speakers? I have yellow, grey, white, blue, purple, brown, green, red, and black...
Post by tk826 on Feb 25, 2012 22:12:48 GMT -5
This is what I have listed for the S601:
Brown - Rear Left Green - Front Left Red - Positive Yellow - Dial Dimmer Orange - Rear common Black - Front Common Gray - Front Right White - Rear Right
* The list of colors are a little different than yours, but maybe it will get you almost there.
Post by legendaryacura8 on Feb 25, 2012 22:29:32 GMT -5
Does common mean ground (or speaker negative)? Shouldn't black be ground for the unit itself? And where would I wire the dimmer to?
Post by tk826 on Feb 25, 2012 23:01:12 GMT -5
I've never had one to test it out, but my best guess is that those are the speaker neg's, and the main unit is grounded through the chassis itself.
I'm also thinking the yellow/ dimmer is the light bulb wire.
Post by sigmfsk on Feb 27, 2012 20:25:14 GMT -5
I triple hip TK826:
> Brown - Rear Left > Green - Front Left > Red - Positive > Yellow - Dial Dimmer > Orange - Rear common > Black - Front Common > Gray - Front Right > White - Rear Right
Hip to that.
> [orange and black] are the speaker neg's, and the main unit is > grounded through the chassis itself.
Double hip to that.
> the yellow/ dimmer is the light bulb wire [the dash lighting, that is turned on when the parking lights are turned on]
Triple hip to that.
Post by Lord Vadus on Feb 29, 2012 15:08:57 GMT -5
Arthur, check the 601 you got from me. I labeled every wire on it with masking tape.
Post by sigmfsk on Feb 29, 2012 19:08:59 GMT -5
Arthur, check the 601 you got from me. I labeled every wire on it with masking tape. Hi LV: Here's what I get: I think that wiring will work, but it's a little different than what the manual calls for. It uses a common ground for all 4 speakers instead of using separate front and rear grounds. your friend in grounds for everybody, arthur
