Post by Mr Mercer on May 11, 2013 19:07:05 GMT -5
Was going to pull the oil pan off to see why I have no oil pressure ...... but the engines going out instead . Front bolts are hard to get to without lifting the motor + drop my steering linkage . Not much progress yet just starting to unbolt the lower stuff . Removed the oil pump first before doing any of this and it seems ok . Bought a new melling pump and a windage tray + gaskets at www.manciniracing.com so this project is now going to be a full blown rebuild . Only doing the lower end , since I had the heads done 3yrs ago . 6 pack pistons ? 9.5 / 1 ? Anyone know what the cam specs were for a 69 / 70 440 police pkg ? At the moment don't really have the funds or ambition to do this ~ but it has to be done . Also by myself kinda sucks too . I'll get some pics on the way of progression .
Post by Steam McQueen on May 16, 2013 1:54:58 GMT -5
Good luck with this stuff, Mr. Mer. A job far beyond my capabilities, I wouldn't even know where to start. I read your post and I see "melling pump", and I'm like what the hell is a melling pump? lol so I see it's an oil pump made by Melling Engine Parts. They must have a good reputation if you're getting your parts shipped Michigan to Ontario from them - Did you get those cam specs? www.moparchat.com/forums/showthread.php?t=97631
Post by Sd.Kfz. 400 on May 16, 2013 3:11:52 GMT -5
I've been told that this is similar to the original magnum cam www.summitracing.com/parts/dcc-4452783ae/overview/I'd still get some newer & lighter pistons, you have to get your rotating assembly balaced anyway with any new pistons(most likely that is) so that doesn't add costs much.
Post by Mr Mercer on May 16, 2013 17:32:30 GMT -5
I went to Mancini racing . There only 40 min away from me . Found a guy around the corner from me that rebuilds engines . He used to build race motors for boats and just drag races now . Hes old school so this will be done right . Just have to pull it out and mess up my pretty floor .
Post by Mr Mercer on May 18, 2013 1:06:20 GMT -5
Almost ready to be yanked .
Post by sigmfsk on May 18, 2013 4:52:51 GMT -5
Almost ready to be yanked . It looks naked without the cop dual snorkel, but a good start on motor building excitement!
Post by Mr Mercer on May 26, 2013 10:05:19 GMT -5
Its out . Now for a trailer ride around the corner to access the damage . No sludge , and the dent in the oil pan wasn't affecting the pickup tube . Must of been the oil pump , even tho it looks to be in decent condition . Once the grime is off this motor I'll check it out to see if it was the original . Somewhere down the road it had mismatched heads on it , that I fixed a few yrs ago .
Post by Mr Mercer on Jun 7, 2013 12:43:28 GMT -5
Update : Its the original motor made in aug/74 and never been tampered with , other than the one miss matched head . Timing chain was extremely worn and camshaft missing about 4 lobes . Little bit of a ridge in the cylinders and the crank has some scoring . Pickup tube was collapsed inside where the screen is and cracked . So far its getting bored 30 over and totally machined from top to bottom . Turning the crank , sizing the rods . My new heads are getting some attention also . Forged flat tops combined with my 452 heads (88cc) will make 9. 3/1 comp .
Post by countrybunker on Jul 12, 2013 17:27:06 GMT -5
Any news on the block Chris?? Hows she coming along?? Now that I finally got me a big block, just gotta go one step above huh?? haha jk
I'm hoping to bring mine up north for a trip when shes done. We'll have to find some empty back roads and go for a run! Your killing me with the pistons though!! I've been contemplating getting some flat tops to up the comression, but $$$.......
What kind of cam you gonna go with??
Post by Mr Mercer on Jul 12, 2013 19:18:52 GMT -5
I just checked it out yesterday . All the machining is done and the crank n pistons are in . Mopar wasn't to kind on the casting process . The rear of my block above the bellhousing looks like its full of flaking rust , but its the casting . Nothing to crazy but I thought it would of came off after the block was hot tanked . Builder said all big blocks he's dealt with have the same casting flaws . We were looking at a bunch of cam #'s but nothing too radical since no headers , stall , or gearing ~ plus being a land yacht doesn't help . Going with a comp towing / rv type cam . He crunched the #'s , so a little over 400hp is fine by me . Going with the stock color too , and maybe put on the stock valve covers and paint the intake to match .... maybe . Then if I'm not impressed , maybe a gear change .
Post by countrybunker on Jul 16, 2013 18:57:35 GMT -5
Sounds like a solid plan man! I'm interested in seeing what cam you go with. I went with the comp XE256h... But am second guessing it now. See a lot of them in the 318s, but not many 440s. However, as you mentioned cant go real radical.. It is a towing cam however so we'll see.
Look forward to some pics, and seeing it come together!
Post by Mr Mercer on Nov 20, 2013 22:22:21 GMT -5
Sounds like a solid plan man! I'm interested in seeing what cam you go with. I went with the comp XE256h... But am second guessing it now. See a lot of them in the 318s, but not many 440s. However, as you mentioned cant go real radical.. It is a towing cam however so we'll see. Look forward to some pics, and seeing it come together! Had the motor now since September , but haven't installed it yet . Bought some energy suspension motor mounts and should change the converter seal since its right there in the open . As for the cam , the spec card seems a bit confusing ~ sae dur 288 int 298 exh Power washed the engine compartment with some touch up paint , but thats about it . Still on the fence about painting the edelbrock intake blue and fixing/painting the stock valve covers . Or just clean it up and leave the chrome ones on . Water pump is aluminum too , so idk ... paint it ? If anything progresses , I'll be posting .
Post by Mr Mercer on Dec 1, 2013 0:44:46 GMT -5
Post by Mr Mercer on Dec 1, 2013 0:46:42 GMT -5
Post by Mr Mercer on May 25, 2014 18:27:02 GMT -5
Woo hoo , its finally in .
