Post by 58hemifury on Oct 30, 2017 12:16:33 GMT -5
Anyone have a source for the outer belt molding window sweeps? Whitey's are really bad, he's going to need all new rubber everywhere, it's either super dry, painted, or both, I'm sure I'll need it for HOB #3 and I might as well assume my Gran Fury will need it too. I found threads on weatherstips and window channels but couldn't find any old threads on this stuff.
Post by srt440 on Oct 30, 2017 18:27:23 GMT -5
My car needs them also..I have some that where made for a 64 Impala that I can get to work. Problem I have is actually removing the glass in order to have access to the screws holding them.
Post by 58hemifury on Oct 31, 2017 13:15:20 GMT -5
My car needs them also..I have some that where made for a 64 Impala that I can get to work. Problem I have is actually removing the glass in order to have access to the screws holding them. I don't have any of mine apart at the moment but I'm thinking something like this. www.steelerubber.com/outer-beltline-70-3804-61 I'll need to pull a door apart to get the measurements but Steele has several different sizes this style, something has got to be close.
Post by srt440 on Oct 31, 2017 18:52:18 GMT -5
I've talked to them..they said I could send originals and they'd make match's for them. Not sure how much they'd charge to do that tho.
Post by 58hemifury on Oct 31, 2017 20:58:01 GMT -5
I've talked to them..they said I could send originals and they'd make match's for them. Not sure how much they'd charge to do that tho. I doubt they would charge for that.
Post by 58hemifury on Nov 1, 2017 8:46:58 GMT -5
I've talked to them..they said I could send originals and they'd make match's for them. Not sure how much they'd charge to do that tho. I doubt they would charge for that. Sorry, I just reread this, you mean actually make sweeps for a Monaco based on your parts, not just match them up. I don't know if they would charge or not, it would open a new market for them, '74-'77 C body sedans.
Post by srt440 on Nov 1, 2017 9:12:52 GMT -5
Actually, made a mistake..I talked to restoration parts specialties. And they said they would made sweeps using the originals as a template. I was gonna do it until I started messing with my door and couldn't figure out how to get the glass out. Lol stores.restorationspecialties.com/
Post by spanks79 on Nov 1, 2017 10:17:46 GMT -5
Restoration specialties mad me new belt mouldings and matched up some window channel. Parts turned out nice, window channel isn't perfect but works. The belt moldings are about 95% of factory, close, closer than the window channel, but still not a 100% perfect match.
Post by 58hemifury on Nov 2, 2017 10:52:59 GMT -5
Restoration specialties mad me new belt mouldings and matched up some window channel. Parts turned out nice, window channel isn't perfect but works. The belt moldings are about 95% of factory, close, closer than the window channel, but still not a 100% perfect match. If you don't mind me asking, what'd it cost you?
Post by christine58 on Nov 2, 2017 12:52:09 GMT -5
I would need a set aswell if it comes down to a minimum order thing.
Post by spanks79 on Nov 2, 2017 17:08:47 GMT -5
If I remember correctly it was pretty cheap. I think the window channel for the whole car was $40 and the belts were $75?
