Post by Deleted on Jun 22, 2017 15:08:02 GMT -5
I tried searching for this, but there are soooo many threads that I need to ask if there are any special considerations that need to be made for swapping in a 14o speedometer, or is it pretty much plug and play?
Post by 58hemifury on Jun 23, 2017 9:03:16 GMT -5
Just take off your dash bezel, the lens, remove the speedo (the cable is a bit of a pain, its sometimes easier to remove the metal dash top in front of the dash pad to reach down and access the cable) and then just reassemble in the reverse order. It's easy once you get into it.
Post by Deleted on Jun 25, 2017 11:22:51 GMT -5
Thanks much! Appreciate it.
