Post by Steam McQueen on Jun 4, 2017 11:11:09 GMT -5
- Very nice! 351 motor. Seller doesn't mention it but this is the Street Appearance package?
The 351W engine is in tip-top running condition. This car starts readily, idles smoothly and drives and shifts like you would expect it to when it was new. It cruises at any speed very well and has lots of power which you can feel most significantly when passing on the highway. There are no fluid leaks - the oil, coolant, and brake fluid all stay at consistent levels.
NEW PARTS & RECENT SERVICE
Original Motorcraft VV7200 carburetor professionally rebuilt and adjusted by a highly experienced technician for $350 New 20 gallon fuel tank New front brake pads and rotors New rear brake shoes and wheel cylinders New distributor, cap, rotor, plugs and wires New intake manifold gasket (the original intake manifold is intact) New water pump, fan clutch, upper radiator hose and thermostat New parking brake cable New oil pressure switch New 100 amp alternator New oxygen sensor New valve cover gaskets New belts Newer "single-row core" radiator Four new Cooper Cobra tires - 225/70/R15 with at least 80% tread left One muffler and tailpipe are newer and the other muffler was replaced a couple years ago Catalytic converters replaced two years ago Rear differential fluid changed two years ago ALL vacuum connections have been double- and triple-checked. The throttle valve cable that controls the transmission shift points has also been precisely adjusted for optimal performance.
